Is there a way to run multiple 3D carves in same “job”. What I mean is (for example) I’m cutting a 3D Christmas Tree but I need multiples. Is there a way to have it run say 2 or 3 of the stl’s without having to stop and start all over between carves?
You can run as many as you want by adding the number of trees in the file. If there is only one tree in the file and you want three you need to add to more and make sure they are set up to cut. Not sure how to tell you to do it in easel I don’t use it any more.
