During the machine setup, jogging the Z axis moves it up
We are trying to set up a 1000x1000 ACME Xcarve, but when we click either of the buttons, the Z-Axis Jogs up. It was working fine before.
Edit:
Now no axis is are moving at all.
When you first power up the machine, do you have the blue LED and three green LEDs lit up on the gShield?
Check to see if the gShield is mated properly to the Arduino and that it is not raised up on one end or the other.
We do see the LEDs, we will check to see if it is mounted
We tried reseating it, the axis more, but we still have the zAxis issue.
/Library/Easel/iris/node_modules/serialport/serialport.js:346
self.serialPoller.start();
TypeError: Cannot read property ‘start’ of undefined
at afterRead (/Library/Easel/iris/node_modules/serialport/serialport.js:346:32)
at /Library/Easel/iris/node_modules/serialport/serialport.js:388:9
at FSReqWrap.wrapper [as oncomplete] (fs.js:576:17)
events.js:141
throw er; // Unhandled ‘error’ event
Error: Error Bad file descriptor calling write(…)
at Error (native)
error - error: Bad number format
error - error: Alarm lock
$0=10 (step pulse, usec)
$3=7 (dir port invert mask:00000111)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
It is unusual for $3 to be 7. On most machines the value is 3. That could be your Z-axis direction problem.
If you wired your machine as Inventables says to, try changing from $3=7 to $3=3 and try it again.
That did not seem to work.
$3=3 (dir port invert mask:00000011)
$22=0 (homing cycle, bool)
so we fixed it. The G-Shield was was not properly mounted or the the connectors were dirty, we cleaned them and reseated and it worked.
