Dust control assembly - Support Bracket
Hi I have a question about the dust control assembly Support Bracket?
It is stated in the instructions to place it in the Front right corner. But with my shop considerations, the Left Rear corner would be SO MUCH Better. has anyone dealt with this, changing the placement of the bracket?
Please advise,
Thanks
Martin
I don’t have one myself, but looking over the instructions it should be doable. You might have to drill a duplicate hole in the bracket so you can rotate it to mound on the other side.
http://x-carve-instructions.inventables.com/upgrade/step5/jpfs_DSC3636.jpg
Other than that, if it doesn’t get in the way of the x-controller, I say go for it.
I was looking at doing right front to left rear - which should be a mirror image - yes?
I don’t see why it wouldn’t work. The machine is symmetrical.
yep, you could place the bracket in any of your 4 corners
I don’t think it is any of the four corners. The holes in the picture looked recessed and therefore the only corners that can use them and not have it stick into the work area are the front right and rear left.
But I don’t have one so don’t quote me.
I Mounted it on the rear left - now HOW do I get the pole to stay in without falling through?
Drill and pin (or screw) it.
I never claimed to be an expert. :smile:
