I designed the shapes in millimeters.(210mm * 293mm)
However, opening a file in easel causes problems.(DXF import 2.0)
The problem is that the file that should be opened in millimeters is opened in inches (210in * 293 in)
테스트.dxf (167.6 KB)
테스트.dxf (167.6 KB)
After you import the dxf, under “Shape”, press the LOCK button to lock x & y. Divide width by 25.4, and enter that number for width.
