hey all, i am having trouble with importing a 20’ arc dxf into easel from rhino cad. when i import the dxf, instead of an arc, i get a straight line. Sometimes when i import ovals i get a deformed oval also. any one have any ideas?
Just checking…are your units in set Rhino in inches and wonder if it would turn out the same if you converted those to mm?
I realized that some curves drawn as a circle or ellipse don’t import correctly. If I draw the shape as a polyline, it works
