A few times now I have needed to pause mid-cut but when I click play Easel aborts (showing the “How does it look?” dialogue) instead of continuing - to try and salvage the material I have tried to start the cut again from the previous home point but it either treats the current position as the new starting point or just flys off in a random direction. Does anyone have any ideas on why this might be happening? Any advice would be greatly appreciated.
Which versions of grbl and Easel are you running? I recently dealt with an issue which made easel do strange things such as you described but at the end of the cut. I was using Easel 0.3.2 and grbl 0.9j. Once I updated grbl to the newer 1.0c, my easel issues went away.
