I have been noticing that Easel will automatically change imputed values. For example ill input and X and Y values, Easel will auto save, make depth chane, check x and y values and they have changed.
Or, if I make a height and width change of a image ( letter, shape etc) change it’s x, y position or depth of cut, look at the H and W values to dbl check the values and they have changed from what I have put in.
Another issues I’ve seen, is ill input a value, hit enter and Easel will change the value automatically.
Just a thought but do you have the padlock locked where you are setting the x and y. If the padlock is locked it will auto change the other deminsion when you change 1 of them.
Maybe share your project, but other than locking height/width together or pinning location for x,y changes to not actually have any effect, no I haven’t experienced this issue and couldn’t explain it.
