I’d like to see Easel carve a more intelligently. What I noticed is that it doesn’t carve based upon where an item is located, but what item was created first.
In the above picture I created the text in order. What Easel will do is carve the One in the upper right hand corner, then carve the two in the lower left, then the three in the lower right, four in the upper left and then carve the five that it has passed over several times. This to me is horribly inefficient. Esp if you’ve got a lot of little items that you’ve rearranged in different locations the x-carve will spend more time traveling to and from cuts than it does cutting.
