EASEL changes dimensions, why?
The imported SVG is 120mm x 110mm,
When opening SVG in EASEL the dimensions are 1585mm x 910mm?
The 4-arrow pick will not turn into a single arrow and can not modify file.
I have done over 40 SVG’s without a problem and EASEL has worked perfect.
Has someone experienced a similar situation?
Thanks & regards
