Hi, Is there anyway to add a feature under the Edit tab “Combine” & “Undo Combine”? Thank you!
there is already a “combine” operation available there (you must have multiple shapes selected). Ctrl+Z will undo the combine operation
it uses an action buffer rather than an an object buffer so you can’t do several other actions and directly reverse it
Thank you for your response. Next time I will make sure it is exactly what I want prior to selecting combine lol
Hi Nox, I have been using Easel for 2 years and suddenly I can’t see the “combine” button at the bottom of my screen???
The combine function is available by selecting more than one design element and going to Edit>Combine OR by Right Clicking and selecting “Combine” OR by Pressing Crtl+J
I have never seen a combine button at the bottom of the screen since I started using the software in 2017.
