Imported several DXF files successfully, Having difficulty with a few very large files that are over sized for Easel…they are too large to load and resize. Is there a workaround for these that I may be missing?
I have brought lager DXF into Carbide Create and then exported them as SVG that i could then bring into Easel…no noticeable degradation to the design either
The only way to work around it is to convert it to an SVG at the moment and then import it.
Carbide Create solved my DXF issue, thanks for the suggestion. Works great !
Got it figured out using Carbide Create, thanks.
Anyone have issues with importing images??
