Hi, i need to generate with Easel a gcode which will work with a Mach3 CNC router, but for now i can’t find the way to do that in the “MACHINE/MODEL” menu. thanks a lot for your help !
There is Mach3 support within Easel.
However, export the gcode and do a test in case Mach3 support it.
Easel -> Machine -> Advanced -> Generate Gcode -> Export Gcode
Thanx Haldor for your quick response !
But what machine and what model should i select in the Easel menu to generate a gcode for Mach3 CNC ?
