Anyone else seeing something like this? It’s not staying on a cut path until it’s done, but keeps jumping around and only taking off a sing DOC each time.
Your link doesn’t work.
I can’t get the video to work, but the problem is pretty simple to explain. The x-carve cuts 1 depth, then moves to the next object, takes off a single depth, and so on, moving around the workpiece. Once everything has been cut down to the same depth, it begins taking off the next depth still one object at a time. The project takes way longer this way.
There is a topic ask about this. Easel was suppose to be updated to fix this. Report it to the topic. "Depth-first" carving for text and smarter "outline" grouping
Thanks for hooking me up with that thread.
