How can I import and use fonts from outside Easel’s library I want to use Autumninnovember-yPR3.ttf (116.8 KB)
Easel dont allow for user-import of fonts.
Your workaround is to write your lettering in high rez in Paint/Photoshop/Illustrator/Inkscape etc and import as SVG or image in Easel.
i have a circuit cutter and i can bring all kinds of fonts into the program there and make and svg and copy it there and save to my computer. then in turn import that svg into easel
Can I import from a Word doc?
The easiest way to get from word document to a SVG is to go via PDF and then import that to Inkscape or illustrator.
Ok.Thank you. I wish I would’ve thought about that.
