Internet is fine… if i flash grbl 1.1a onto the board it works fine… 1.2d is setup for 5 axis, x, y, cloned y, z and a. Thats the only difference, otherwise configuration is identical.
yes, easel generates gcode that operates with dual Y (y1 and y2) but not another axis (like a rotary typically called the A axis)… Btw, you can simple export the gcode from easel and use one of those other senders… all 3 of my cncs work fine with ease, but I still export and send with openbuilds control since I like the user interface better…
Internet speed is irrelevant to the issue at hand. Once the page loads, there are only a few operations that actually require an active network connection, connecting to the cnc is not one of them… Watch this:
I will try dropping axis 5 today and block reporting of the same axis more than once.
I dont use easel to generate gcode… i only use it as a gcode sender… the cloud feature is handy for prep and process in different places, although it is buggy as hell, it still gets the job done.
