may i kindly ask help to lay this sketch on easel?
where i can change the dimensions but not the sketch.
thank you in advance.
gerry
`sketch.PDF (14.5 KB)
gerry
I pulled into Inkscape, imaged traced it, downloaded an SVG then created it in Easel. Each workpiece shows the steps
https://easel.inventables.com/projects/jrWqG27EhEu9jn-8BzT8eA
steve,
i almost wanted to start curving it out when i saw it but C=.75" slotted cut on middle is missing. i’m going to use these as the legs for a round top stool. once i get the revised lay-out i’ll start making it.
thank you so much for your time and patience.
gerry
Anytime! glad I could help, Steve
