Hi. I am trying to generate g code for my project. When simulating roughing path box appears it starts then stops before completing the simulation. As my project only requires detail engraving why is this happening and how do I generate detail g-code?
can you share the project so that I might try to simulate on my PC…
In Easel go to Project>Share and change it from private to Unlisted… don’t worry I can’t edit your copy of the file
I’ll make a quick (private) video of the resolution and post it back on here
Hi Seth. Problem resolved. The project was quite complicated and I was impatient waiting for simulation to complete. Decided to leave easel to finish simulation, which took quite a while, but all was fine eventually. Many thanks for your response.
Glad you got it sorted!
