Easel "metrical" presentation
Hello Inventables Team,
@Zach_Kaplan
I saw a failure in the presentation/ conversion of metrical speeds and so on .
As an example for the feed rate of roughing:
in Inch:
In mm/ Metric:
But 13,8 inch/min = 3,5 m/ min or 350 cm/min or 3500 mm/min not : 350 mm /min
Could you please change the unit from mm/min to cm/min then the valuor are okay, or at one 0 to it, then it is also correct.
Best regards
13.8inch/minute * 25,4mm/inch = 350mm/min
Easel math is correct :slight_smile:
