After running toolpath, machine returns to 0,0 but upper right progress stays stuck at 100% with pause and stop buttons that do not work. This just started last week. I cannot import a new toolpath and continue using “last home position” because I have to close Chrome, restart, relogon, and then get the “Carve” button back. Anyone seeing this?
I use chrome and have not experienced this issue as of yet.
The work offsets are stored on the controller, not the computer.
To your issue. How are you generating gcode? I’d guess you’re using a different post processor without a command that tells Easel the carve is done.
Can you share a project or gcode or just the last 10 lines of gcode?
