Is it possible to bend text? Creating a circle and then wrap text around it.
To myself. Maybe if you used one letter at a time and placed it and then changed the angle (degrees) might work.
It works, although not easy. Just need a protractor in front of you and change the angle on each letter accordingly. Sorry I kind of answered my own question, but if there’s an easier way, please let us know.
Have you tried using the circular text app through Easel?
Thanks so much, I will check it out.
It’s best to curve/wrap your text in a separate app (Inkscape) and then import the vector graphic into Easel.
