I am planning to carve a small sign and selected a 60 degree V-carving bit. There is a small icon that reads “PRO” adjacent to the V Bits category. When I click on the icon I get this message: “Selecting a v bit enables you to v-carve. Carving requires use of an Easel Pro carve day”. Not sure what that means. Am I required to watch a tutorial or something in order to be able to access the V bit carving software, or does it mean nothing at all?
First Time V bit carver.
Tony
If you didn’t purchase Easel Pro then you only get 4 days a month to use the “pro”. I believe v-carve is part of the pro package.
Yep. Scroll down in the box that comes up and you will see the choice to use a pro day. Do that and you can v carve and use additional fonts for 24 hours. (So it’s good to plan a few projects to take most advantage.)
Some Fonts are only available as Pro option as well.
The raster cuts, the ones that predominantly go either across the X-Axis or the Y-Axis only also require use of an Easel Pro day.
{:0)
Brandon Parker
Thank you!
Thank You!
