Easel Running Slow
is anyone else’s easel running slow? before i could zip around making designs or editing stuff now there is a 3 to 5 sec delay on everything very annoying.It was fine about a week or two ago now its not nothing has changed on my end.
Hi Devon,
Can you share the link to a project that has been slow?
Jeff
http://easel.inventables.com/projects/R-7wSkGoZ4_spKfrW20I-g
here is link all i was doing was putting white boxes around the image it had black frame.any timei would copy and paste the white boxes there was a big delay and when i would try to move them it would also delay. thank you
Hi Devon,
Thanks. I can confirm there is an issue with responsiveness in this project that I’m seeing on my end, too. We will investigate this and try to get a fix out quickly. We’ll follow up when we have one.
Jeff
i appreciate it thank you
Hi @DevonKelble,
We found & fixed a bug that was preventing the detailed preview from canceling quickly after it has previously timed out, and causing the interface to become sluggish when working with complex projects.
Cheers,
Jim
Thank you
