Uploaded an SVG to easel and selected Cut > Inside. It keeps selecting both on path and inside…you can see both boxes grayed out. When I tried to click off of one it would would selected inside and outside. No matter what I would do it would always select two cut parameters. I tried clicking Fill to see if that would clear it out but then it had cut “fill” and cut “outside” selected. It seems like a glitch. Anyone else? I’ve tried both Chrome and Safari.
Can you share the project?
I was able to solve it but not sure if it was an easel issue or my svg. I am create images in Photoshop and then tracing with Illustrator. I did not click “ignore white” when doing my image trace but after doing that and re uploading it fixed the issue. Thanks for responding though.
