Easel Tabs
I have a pattern in Easel in which I am using tabs of course not to cut through all the way. Some areas that should have a tab don’t have a tab. Is there any way to add more tabs than what Easel is adding. Thanks in advance
On the bottom of the cut dialog box it gives you the option of adding and subtracting tabs. You can also click and hold a tab and move it in your design.
