I started a project with basic Easel. I have since gotten Easel Pro. How do I get this project to recognize Easel Pro. I want to add a V-Bit to the project.
You can either use fonts from easel pro and it will reconize that or when you lay it out and select a vbit for your cutter it will reconize that.
I have tested your theory by replacing the font with a Pro font I use in another file. In the Non-Pro file, I am not able to select a v-bit. In the file created with Pro, v-bits are selectable.
You should be able to select a vbit in either one.
“Pro” is prompted when a Pro-feature is selected. Otherwise plain vanilla Easel will remain.
Got it gentlemen… thanks
