Easel Tool path Question
Today when I went to carve a project Easel did something I haven’t seen before.
It started by carving in the opposite direction from what it always has in the past. When it finished that, it recarved the same shape but in the opposite direction.
The artwork was built as it always was, in Illustrator, and imported as an SVG.
Any ideas what would cause this behavior?
Can you share the project?
ornament redos- CNC
This is the file that we imported into Easel.
Interesting.
Your paths are actually double paths. I’m not sure why the direction is reversed though. I didn’t know Easel could do that. It’s like one path is inside out…maybe someone who knows vectors better can explain.
Here’s a fixed SVG:
No fill
houseKeyThing
Filled, so you can see it.
houseKeyThing
