Easel Toolpick Generation Error
https://easel.inventables.com/projects/HHuelJSVzVLp4salhfk2Sw
Hi Gregory,
You need to share your project publicly (the second link when you select share), and please give a bit of a description as to the difficulty you are having. We cannot see anything, and have no idea how to help you right now.
The issue was an error during tool path generation. I solved the issue by changing the bit from .5 mm to 3 mm. Although, I was hoping to get the finer detail of a .5 bit.
I have changed it to unlisted.
