https://easel.inventables.com/projects/rIdxSqiMcAkYhiHUf9Sg2w
Can someone tell me what I am doing wrong ? I have tried all sorts of depth settings but the text does not show up in preview. I have not yet tried cutting the job. Thanks
Hello-
Likely the bit that you have selected in your cut setting in the upper right hand corner of the screen isn’t able complete the cut. Try selecting a smaller cutter and that should populate the text in the preview screen.
Hi Bob!
It looks like the project you tried sharing isnt public so I wasnt able to see your setup but I think what @DanielRomberg said is likely the case. If the text is smaller than the bit can carve it wont show up. Try making the text larger or selecting a smaller bit such as a 1/32" or 1/16" bit .
Absolutely right Daniel, problem solved. Many thanks
