Has anyone ever had problems with the eccentric nuts that keep the gantry tight to the X run of the extruded aluminum wearing into the gantry. The wal of the gantry has worn inward not allowing the exxentric nuts to keep things tight.?
Call Inventables tech support and work out a solution with them. They’ll either replace the part or sell you a new one.
Thank you…
