I created two custom tool trays.
One for end mills and measuring, the other for work holding tools.
The material is building grade 1/2" PVC sheet.
Here are the Easel projects:
The only clever thing I really did was use my scanner to scan the outline of the calipers.
I placed the calipers directly on my scanner.
I imported the picture into Inkscape, simplified some of the nodes and then exported a SVG; tedious but loved the outcome.
I did use Easel for creating an offset. I could have used Easel to do the trace but Inkscape was just as easy.
I tweaked a few nodes in Easel, deleted a few extra nodes, and did a successful test cut.
Hopefully now myself (and others) can be onto a much more organized shop!
