Hi guys, I’ll start with my first question - I need to use my indybuild CNC to engrave some trophy plaques. The font on easel is just to complicated and all I need is a single-stroke font using a diamond tip drag bit.
Can anyone tell me if this simple operation is even possible in easel?
thanks
It is possible, kinda. You would need to prepare your design using the single stroke font outside of Easel and import the design into Easel preferably as a SVG or DXF file type, and then Easel can be used with “on path” cut type to do all of the toolpaths and make the carve.
Thank you for replying @SethCNC. I did try your suggestion and it ‘kinda’ works as you said, but still not quite as I need it. Any further suggestions would be appreciated
Thanks
Jude
