What settings are causing my homemade CNC router to engrave not as intended, but in a mirrored image? My CNC is controlled by Arduino Uno. The text is a simple text “Calvin” generated from the Easel text application. Any help would be greatly appreciated.
You probably have you X-axis mirrored (unless there’s an option for mirroring in Easel?). If you have homing switches you’ll need to adjust your homing direction. You can then either power down and re-wire your motors to reverse movement, or you can flip the invert bit in Grbl
I have some kind of the same problem. I have the 3018 cnc machine (banggood) but I can’t get it running propely. Some how, the image is mirrored and also upside down. I switch the 2 outer wires on the connectors of the z and y axis and it seems to work for the upside down issue. But still, it mirrors the jobs. Anybody have an idea? I also changed the $2 to 1, 2 and 3 but this doesn’t make a difference.
Hello John
Did you ever get a solution to this? I have the same machine and have exactly the same problem. After I made the before mentioned adjustments the Unit went berserk and instead of carving a simple name, the spindle plunged deep into the work.
Thanks for the quick reply!
Machine is generic make 3018.
At start Y axis was moving in wrong direction so I set $2=1 to invert the direction.
Next did a test of a simplistic text “Strider” designed in Easel. I then save gcode and import to candle to run.
(Basically because my internet speed capability on the laptop is well…out of date)
This came out mirrored and upside down. After some research I changed $3=4 to invert both axis’.
Not sure if that was correct. Instead of testing at that point which i should have done I went back to easel to create a different style of text this time playing with ramp setting in cut settings…ran this and got squeaking and beeping from ??? board? motor? In addition did not come down to contact work piece… stupefied I went back to original test code. Running this the spindle drove straight down into the work…deep.
Sorry for the long post
So I think I have a few things working against each other. Pics below are settings, the machine and the first test run result.
$2 is not a setting to invert an axis like that.
Can u set this back to 0 and then only adjust $3 to control directional changes.
This should resolve the current issue.
Unless you’ve designed your own controller then $2 is always =0
Thanks,
I will try this in operation. Originally during setup I noticed the Y axis was traveling the wrong way using jog commands. Down arrow would move bed back not forwards. I read you can invert direction of axis’ using $2. This corrected the initial problem then. I’ve now reset $2 to 0 and bed moves as it should. Peculiar.
Going to zero all axis’ and try again…
Retried the text job. Disappointing and confusing… it’s still mirrored and upside down. Other point to note. Running gcode the machine is expecting “home-starting point”
to be upper left corner of bed and not lower left corner as is shown in job visualization
EDIT: Just realized $3 is set to 4 which according to table above does nothing to invert axis directions N N
Setting should be 3 again referring to table above. I have no clue why I selected 4??
It’s not working as one would hope.
Setting $3=3 now has z axis inverted.
0 is also no help. Setting to 0 or 3 now inverts z axis.
This wasn’t an issue before.
I’ve tried resetting, powering off after setting grbl to no success.
