When a mistake is made I have found the perfect way fix it.
These Mohawk epoxy putty sticks are really perfect for repairing any mistakes you may make on a project. The epoxy comes packaged in what looks like a 1 inch diameter cylinder of modeling clay. It is actually a two part epoxy with the harder in the center of the cylinder. To use it just cut off as much as you think you need and then just knead it together between your fingers till it is a uniform color. Then you have about 5 minutes to mold it where you need it. Then in 30 minutes is is hard enough to sand. It comes in a variety of colors. I just made a mistake that caused a bit to gouge into a project (forgot to set the Z zero after changing bits). The epoxy fixed it perfectly!
http://www.mohawk-finishing.com/catalog_browse.asp?ictNbr=113
https://www.amazon.com/Mohawk-Finishing-Products-Epoxy-Putty/dp/B013RKDKWO?th=1
