Equally spaced circles
Sure do appreciate the help and insight here. I have an issue with cutting out 1/16" deep circles in a 4" wide by 21" long board spaced properly so they would be centered when I cut the board into 4x4 blocks. I try to allow for the kerf of the blade but nothing seemed to work right. The grid on the drawing page is in 1" increments but my blade’s kerf is 1/8". Does anyone have a method within the application to set up this type of carve? Thanks everyone, in advance.
For starters if you zoom in on your project it will change the grid spacing.
Wow, just goofing on my tablet and you may have my solution. Thanks, I did not know the grid changes. The change is actually in 1/8" increments which would be perfect. I’ll give it a try tomorrow. Thank you for the suggestion.
