Error: Alarm lock and Line overflow?
new to this game, but my first 3 hours of carving went without any problems. Now, I can’t get the machine to even move. Machine inspector says this
@Andrew13 Was that imported code or created in Easel. Can you share the project? That error, I believe, is due to a memory constraint for which grbl has a max limit of characters per line. Easel definitely should not generate gcode with a problem like that.
It was created on Easel. Just a basic folding pocket comb outline and hole. Not exactly sure how to share it, but I’ll see if i can figure it out.
http://easel.inventables.com/projects/Thm3L6ylctDbg4x3oAYPSQ
I tried both of those, but every second it would add a new line of code repeatedly after that. I’m using my Mac Book and just booted up my desktop to see if the USB connection is janky. Thanks for the help
