Hi everyone, I am trying to carve but when I hit carve the time comes up with: Infinityh NaNmin Same things happens if I simulate the project. Any suggestions?
thanks
It’s hard to say without seeing your project. When you see NaN, that means “Not a Number” which comes from computer software when you try to make it do calculations like dividing by zero or taking the square root of a negative number or starting with values that are not defined. Either something you’re trying to make the software do is wrong, or the part of the software you’re using is not well written.
