Lets’ say i put in a font size of 4". In the drawing & simulation the font show up as 4". But when I make the design, the font size is usually 1/2" or 2". What is my problem?
This is a result of the Calibration of Movement settings for the CNC itself not being set correctly.
Depending on what model CNC this is I might be able to provide the defaults for you to use. (what model cnc machine are you using?)
OR if you prefer you can run a manual calibration as shown here:
