Can someone help me
this happen every time I create tool path.
Link below of the my project
Can someone help me
Your z depth needs to be less than your stock depth. You have a 1.5" maple stock, and 1.5" z-depth. Changing the z depth to 1.49" allows the tool path to generate.
Also keep in mind the undercut at the bottom of the bowl will not carve.
You may also want to add some more padding width as the toolpath does not cut the perimeter of the model with the current settings.
Thanks James, it worked
Yes undercut will be done using router
Padding causing cutter to go in Z during finish cut so I am avoiding it.
what is the height of your material?
