I just finished cutting this for our home. I made one for someone else last week and my wife wanted her own.
looks great. did you vcarve it.
looks beautiful, great job.
Yes, I used Fusion 360 to model the shape of the sign and v-carved the sketches on the top face of the sign. I also used this time to chamfer the edges since I had a 1/2" 90 degree V-bit in the router. This was originally 3/4" cedar planed down to 1/2" to get rid of a bow in the board.
you did fantastic.
What did you use to create the V carve tool path? I assume you imported that into Fusion 360?
Modeled in Fusion 360 and used the Engrave option under 2D tool paths. The tree was an image I converted to an SVG and the text was just typed in using sketch text.
I set up a custom tool library with all the bits I own to make generating tool paths quicker
Looks great!
Can you share the file please.
@PauloMunoz I remade the design in Easel. Workpiece 1 is the v-carve, workpiece 2 is the 1/8" endmill, and workpiece 3 is meant for layout verification.
