do you know if estlcam will work with this board?
As far as my understanding of the german language reaches, i can make up that it is based on a arduino board with Grbl. so maybe its possible to install the estlcam driver?
Hi,
the issue with the motion planner causing the machine to run extremely slow should now be resolved with version 9.006
Can someone please verify this?
(Sometimes if the file e.g contains a lot of 90Ā° turns from pocketing operations there may still appear a warning because the warning does not discern between avoidable and unavoidable decelerations but instead just checks if machining time is more than 1.25 x target time - but the many many unnecessary decelerations of previous versions should not happen anymore.)
@JarnoOoink:
I unfortunately donāt know this board - but from what Iāve read it is very likely to work.
Christian
It uses the ch340 usb chip. Many software programs have problems with it especially at higher baud rates.
CH340 is fine - I have an Arduino Nano clone with this chip.
It just needs a different driver than the genuine Ardunos.
Just done some tests, it has resolved it for me for most of my files, there was on file which it still occured on, but as you say was pocketing with a lot of 90 so thats fine.
I found all my answers in here - than you all!
Hi,
it should home upwards.
What happens if you press the āupā arrow in the control window? Will it move up or down?
If it moves down youāll just need to invert the z-axis direction in the setup tab.
Christian
When I press the up button on the controller the result is what I expect it to be. It is only when homing the Z axis is behaving strangely
Hi,
which version are you using?
Iāve just verified it is working correctly with version 9.018 on my test machine.
Christian
Hi,
I am also using 9.018
I am running a modified Prusa I3 for light cnc work and I would like to run grbl with Estlcam. I have a similar problem i am running 5mm Z axis rods. That puts my steps at 4000! Any ideas of how i can use Estlcam for my purposes?
Hi,
do you want to run it with GRBL and external g-code sender - or with Estlcam itself?
If GRBL with g-code sender just select the āGRBLā preset in Estlcams āSetupā / āCNC program generationā tab to create GRBL compatible cnc code.
If Estlcam:
Christian
Iām hoping to run it with Estlcam. I think I figured it out. My x/y are 80mm and I believe my Z is .8mm (thread pitch) not 4000. I will either be using a Grbl port for Printrboard with UGS or switch to Uno/Estlcam. I have not decided yet. One of my main concerns is how to set up end stops. Iām very new to the CNC side of things and Iām finding out I cannot approach things the same.
Thanks.
Hi
Im using Mega 2560 + ramps 1.4 + drv 8825 on Estlcam.
Everything work fine, but Z axe on stepper are not moving UP only Down. If change Z axe to inverse, move Up and not Down.
Any ideas ?
Hi,
this is strange.
Iād first say disconnected dir signal (faulty board or damaged arduino) - but if this is the case it wouldnāt move in the other direction after inversing the axis.
Have you tried interchanging the DRV8825 drivers? Maybe the one for the Z-axis is faulty.
Christian
Hi,
Thanks for response.
I wrote wrong, in no reverse mode, motor turn clockwise, if i set reverse motor turn the same direction (clockwise) i just must press another arrov. but rotation stay the same. When i physically switch wires (from 2B2A1A1B to 1B1A2A2B) motor rotate anticlockwise. Stepper and DRV is ok i tested both on X axis and work fine.
And you right it its strangeā¦
Hi,
in this case there should be only two options left:
Christian
Hi
OMGā¦ omgā¦
I never pay attention how is something soldered together.
When i look ramps through the magnifier 6 pins is soldered together !!!
Yes ramps is from China.
I would not be surprised if I found some rice in the IC ā¦Chineseā¦
thx god for org. arduino still working fine.
So i removed solder between shortcut pins and i got my Z axis finaly
Btw i like your software.
Thx for your time and help .
Hi,
an easy way to zero workpieces with some aluminum tape and Estlcam:
Christian
