Just an update: the issues with some SVG files are now solved in version 8.108
Only texts still need to be converted to paths (font support is unfortunately too complex for me at the moment).
If someone still experiences problems please let me know.
last night i downloaded some fonts and installed them, and they appeared in the selection window of estl cam. I decided to make a vcarve toolpath, and i was verry pleased with the result.
I’ve just uploaded a beta version with feed override so you can adjust machining speed from 1 to 100% while the machine is running: www.estlcam.com
There are also a few other changes like probe and limit switch support and it will automatically create a backup of the controller so it can be restored e.g. to GRBL with just 1 click.
It is still a quite early beta version - but I’d be really happy about some feedback.
The save restore part is working, I just just successfully installed and restored. When I loaded the beta it lost my registration data, I had to re-register. I haven’t had time to fully play with it yet, but in the initial setup I told it to use inches/minute. Later I told it to use mm/min for the setup, but not all the fields changed to mm/min, some stayed in in/mm. This is for setting up distance per rev, acceleration etc
There are 2 places where units are set: the “Basic settings tab” and the “CNC program generation” tab. For the internal controller only the “Basic settings” tab is relevant - it will override any conflicting settings in the “CNC program generation” tab (that one is only used to generate g-code for other CNC control software).
If someone can send me a well working preset I’ll include it in one of the next updates. I unfortunately can’t create a preset myself because I don’t have a X-Carve.
When I enter the new number (320) and hit Enter, or tab out, it changes back to what it was (100). Max Feed Rate does keep the new value when I do that.
distance per revolution is currently limited to 100mm or ~4 inches.
Do you really have more than 100mm per stepper motor shaft revolution?
I can increase the limit if necessary but 320mm per revolution seems very very strange to me.
As far as I know the value for the X-Carve is 1.25mm if you use the M8 screw and something about 2.117 for the ACME scew.
There you can also change the keyboard layout if necessary…
To use the keyboard first make sure the keyboard control button is enabled:
So the keyboard layout is basically split into “direction” keys to the right and “speed” key to the left:
If you want to move slow just press one of the direction keys…
If you want to move a little faster simultaneously keep “2” on the
left pressed…
Even faster keep “3” or “4” pressed…
And for maximum speed “5”…
And finally you can also use an Xbox360 gamepad:
Be aware of the triggers: the joysticks alone won’t accelerate the machine to full speed so they can be used for precise adjustments - to accelerate to full speed you also need to press one of the triggers.
Christian, can you either post on your web site, or include in the software a changelog. It would be nice to know the changes between versions, especially when you do a lot of releases quickly like you are right now.
