I am trying to evenly space some quarter-inch holes
I want the spaces in between the holes to be the same
I can align them horizontally or vertically but I cannot see how to evenly spaced them (a half-inch space between each hole)
You might see if the Replicator app in Easel can do this for you
Thank you, I will check it out
Why not just select each one, change the position type to “Center,” and just update the X position manually? If each one is supposed to be 1/2" to the right of the one its left, that makes the math super-duper easy for you.
You can easily start the first object at x=0 for the center location and then when you are all done creating everyone simply select all of them and place the left x location where the want the very left one minus half the width of the object.
{:0)
Brandon Parker
