What happened to ‘export g-code’ in easel pro? If it is there where is it located?
Neil’s answer is correct, but that location may be temporary, per this update in the help menu that was added when inventables added the multiple machine profiles function a little over a month ago…
The new location will now download the file in 2 clicks
Thank you both for your replies. I have seen the ‘download’ in both locations but interpreted the term to mean bringing a file into easel. I am hoping to export a project file to gsender so that I can use my touch probe in all three axis. I will give your suggestions a try.
‘Download’ worked on the first try! Thank you. I assume because easel is a web based program all project files are saved on the Inventable server. To open a file with a different program it must be downloaded to my hard drive and can then be found in my download folder. I am very new to the CNC world and really appreciate easel as an all in one program. I hope xyz axis probing will be developed in the future so that moving a file to another program won’t be necessary.
If you’re using the Triquetra touch plate that will work with Easel.
Russell
Thanks for the tip Russell, I will look into that.
Don
