looking to extend images
for example, a short tree
I’d like to grab the tree trunk to make it taller without changing the dimensions
Thanks
Thanks
You have a couple of different options:
You can double-click on the object to go into “Edit Points” mode or do so from the object pane. You can then select a point to move around and change the design.
You could add different objects and then combine what you add with the original.
You could also add split the trunk off by adding a thin zero-depth horizontal rectangle on the trunk, combine these objects, and then send the resulting object through the Xploder app. Then extend the bottom trunk portion as you wish. Afterwards, you can just recombine the lower portion with the upper portion.
Option 1 might be easiest…
{:0)
Brandon Parker
