don’t suppose I could get an EPS file…
Is the resistor 1k? I just cut the file last weekend.
Yes the resistor is a 1k. I hope it works out for you.
For those who are not to keen to do their own PCB-work there are lots of 65mm LED-rings for cars that can be used for this purpose
Thanks. I am also working on a printed diffuser and have an SVG of the board that I am tweaking. Will probably publish the project when done.
No problem! That sounds interesting, would love to see the pictures when it’s all completed.
If I bought such a thing, how would I power it via battery or plug? (I actually see some benefit to a battery pack.)
I do household type wiring, repair lamps, etc. But am clueless on this type of thing.
Those particular LED rings run off of 12v dc. You would need a dc - dc converter from 24v to 12v, if you connected it to the power supply that came with the X-carve
@DrewKasel - search ebay or Amazon for DC-DC buck converters, the cost “nothing” hence the “buck converter”.
You’d use one to regulate 24V down to whatever you need
Something like these:
https://www.ebay.com/itm/LM2596-2X-DC-DC-Adjustable-Step-Down-Power-Module-7V-35V-to-1-25V-30V-3A/273388909512?hash=item3fa73fb3c8:g:Af8AAOSw76lcRoaO:rk:1:pf:0
I have been working on some mods to Jason’s design.
