F-Engrave Letter spacing?
Hello ,
Has anyone ran into this particular problem with F-Engrave…
some of my fonts the spacing between the letters are off and i cannot figure out a way to solve.
example of what i am talking about , attached. the l and the c are way to far apart and the other letters should connect, but do not in F-Engrave. it is a ttf font
Usually this sort of problem happens because a font adjusts such letter pairs using kerning data in font metrics which are not being applied by the app — unfortunately I don’t believe that F-Engrave has an option to enable the use of kerning data — instead, set the text in a program such as Inkscape which either uses font metrics, or allows one to adjust inter-character spacing, then save as a format which F-Engrave can import.
Thanks !!
