Why can you get faster and cleaner cuts in wood with the x-carve Pro
Stronger Spindle (less runout and can run up to 24K RPM) by a VFD that keeps RPM constant by adjusting output based on current draw) ,Ball Screws (no stretch = more accurate & Faster), Linear Rails increase accuracy as well as the more rigid frame using thicker aluminum and better profile design…
And then there is the larger footprint of the 4x4 which would mean more products completed in a single carve…
