This is so good! Thanks so much for sending this over. Lots of people on our team have already seen this and I wanted to make sure you knew we are taking a good bit into active consideration for future releases!
Brandon_Cullum,
Thank You for reaching out to me in response to my Easel Feature Request. I certainly understand and could agree that all aspects of my request may not be incorporated. Based on Company policy and/or Inwork feature does not match up. Looking forward to seeing some upgrades.
The latest software release solved my Inventables case (137259) which I believe was the cause of my issue during its beta test cycle. so I decide to sign up for a Beta tester.
My last 3 years before I retired from Boeing Comm Aircraft Group. I worked on a system update from O&IR (Operation and Inspection Record) paper system. To an online web system. Key core item, the system was to design around Standard Web Design ie(All Active Buttons = colored, Standby Button = Dimmed, Inactive non-functional buttons = Grey out)
Btw: you should check out CNCjS which has all of these (resembles pathpilot on my Tormach)
