Hi
I have decided to generate my own custom g-code processor as long as i need to trasnform by command line dynamic stls and i did not get any tool working in order to do so
Additionally this would let me generate 2 toolpahs in oder to deal with different bts
My concern right now is regarding feedrates
- Whats the difference among feedrates defined on M3 and G0&1 commands?
- If i set feedrates based on ipm, where do i set the diameter of my bit?
- Is there any recommended table of feedrates for each different bit on wood surfaces?
I’ve been googling this , but at least the info i find is not quite obvious for beginers
Thanks lot
This is my sample
; Comienza el bloque inicial
G17 ; Plano de trabajo XY
G21 ; Escala en milímetros
G40 ; Radius compensation off
G90 ; Coordenadas absolutas
G94 ; feedrate por distancia mm
M3 S12000 ; Sentido agujas del reloj rotación de 12000 mm por minuto
M9 ; Coolant Off
T1 M6 ; Seleccionamos broca 1
; Comienza el bloque de fresado
G0 Z20 ;Levantamos el cabezal 20 mm
G0 X150.000 Y110.000 ; Posicionamos en la coordernada 20:20
G1 Z-2.000 F228.6 ; Bajamosel cabezal 2mm
G1 X150.000 Y110.000 F762.0 ; Esquina superior derecha
G1 X50.000 Y110.000 F762.0 ; Esquina inferior derecha
G1 X50.000 Y50.000 F762.0 ; Esquina inferior izquierda
G1 X150.000 Y50.000 F762.0 ; Esquna superior izquerda
; Tareas finales
M5 ; Paramos rotación
M2 ; End of Program
M30; End of program
