Oops, I thought you were referring to resurfacing you waste board. I don’t use the standard hole pattern that came with the X-Carve Waste Board. Instead I use T-Slot Tracks. I still have the original waste board but only use it to fasten the tracks to and then insert strips of mdf between them with a few holes to use to screw them down to the original waste board.
